STM32 MCUs Products
Stm32l100
Posted on March 12, 2014 at 08:35Hello, What does stm32l100 follow Big Enidian or Small Enidian..?
sundar by Associate II
  • 1755 Views
  • 4 replies
stm32l-discovery weird blinking on LD1
Posted on March 12, 2014 at 23:46Hi all,I have a question regarding to LD1 COM LED of STM32L Discovery board.From http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00027954.pdf, it mentioned LD1 COM turns green t...
How to calculate and set the SPI speed ?
Posted on December 19, 2013 at 15:03 Hello everybody, I communicate with a popular screen, the DOGM128 (ST7565RLCD Controller) with my STM32F4 uC. Sometimes, when I power on my board, the screen have troubles to be initialized (it remai...
Error: Using CubeMx to Generate Project for STM32F429
Posted on March 10, 2014 at 03:49Hi all, I used STM32CubeMx to generate project for stm32f429, a .ioc file(v510.ioc) was generated(see the attachment). The Keil MDK was collapsed when opening the project V510.uvproj. Why? Did ST had any example(ioc...
albhuang by Associate II
  • 2907 Views
  • 9 replies
STM32F107 Uart 5 always sets MSB when sending
Posted on March 11, 2014 at 18:56Hi everyone, the title says it all. Scope tells me the timing is fine and the signal looks like it should. Receiving on the other end works. Except the MSB always being set to 1, no matter if I try to send values hig...
Stm32f4 discovery formware update + CoIDE
Posted on March 12, 2014 at 12:04Hello everybody! Yesterday I upgrade my stm32f4 discovery st-link v2 firmware. After that the coocox give error at erase flash. I have another board with old firmware, this is working well. What can I do this sutiati...
totti001 by Associate II
  • 1208 Views
  • 3 replies
Using Standby Mode with the RTC
Posted on March 03, 2014 at 17:40Hello everybody. I am developing some test firmwares on a STM32F103 based board. After some working programs using the sleep mode, now I need to do some experience with the much more powerful standby mode. I need to ...
emilio by Associate II
  • 6816 Views
  • 18 replies
Discovery board programming problem
Posted on February 06, 2014 at 11:54I am using IAR with STM32-Value line discovery board. I am trying to program the kit but not getting programmed giving error like below, Fatal error: ST-Link DLL not found   Session aborted!  Can any one guide me ...
anand by Associate
  • 1247 Views
STM32F303 SPI1 slave
Posted on March 11, 2014 at 19:18Hello,I am using the STM32F303 with SPI1 in slave mode and no data packing.  I am seeing an issue where I will get an interrupt when a byte is received, but the status register says that there is nothing in the recei...
Detemining the driving capability of an STM32 output
Posted on March 11, 2014 at 21:48I'd like to model if it's practical to drive an STM32 output into a transistor.  I've got some Optimos 3 transistors with a 2.8v Vth:http://www.mouser.com/ds/2/196/BSC340N08NS3G_rev2.6-76670.pdfThe transistor would b...
dannym by Associate III
  • 1377 Views
  • 1 replies
