julien2
STA8088FG
  • June 5, 2013
  • 606 views
Posted on June 05, 2013 at 20:30
Hi
I have a question about STA8088FG but no place in forum for it
The documentation is so thin I dont know what is required to program it
is it already programmed?
how to use it? does it output formated nmea? what are the command set?
    Tesla DeLorean
    Guru
    June 5, 2013
    Posted on June 05, 2013 at 21:21
    Assume you won't, this is a part for commercial clients likely to be spending several million dollars on parts (ie Apple, Nokia, Garmin, etc). If this describes you, contact your local ST rep.
    A better question is who is using this part in their modules
    julien2
    julien2Author
    Posted on June 06, 2013 at 13:53
    Hummm I see
    I don't have millions of dollar to spend, but I would like to make a board out of it :)
    Ill ask my rep
    Thank you
