STM32 MCUs Products
STM32F429 24 bit RGB888 mode not working
Posted on November 03, 2014 at 15:41We are facing problem with 24-bit RGB888 mode. Most of the time 2-3 LSBs of R, G and B have noise data coming out.  For some particular pattern of data like all 1s written to frame buffer the data coming out as ex...
mahendrai by Associate II
  • 1274 Views
USB FataFS and RTOS
Posted on November 03, 2014 at 08:07I need to sent a message to my main task, that tells it USB is connected. (so I can display a message on screen, and display file names etc.)What events are generated? any documentation or sample code on this?It d...
Johanan1 by Associate II
  • 1788 Views
  • 9 replies
STM32F0xx Hal Documentation
Posted on November 03, 2014 at 16:15Hy everybody I'm looking for a HAL library documentation for the STM32F0xx especially for the STM32F072RB. Like the one for the STM32F4xx UM1725 http://www.st.com/web/en/resource/technical/document/user_manual/DM0...
pfischer by Associate
  • 940 Views
  • 1 replies
How to deal with I2C acknowledge failure
Posted on November 03, 2014 at 14:25Hi, I am using STM32L151 and try to communicate over I2C with STM32L151 as master. When I send out an adress to a slave that is not there I don't get an ACK, SDA stays high. With my configuration this results in a...
mmensch by Associate II
  • 1924 Views
  • 1 replies
''No ST-LINK detected'' (STEVAL-IKR002V4)
Posted on November 03, 2014 at 13:01Hi! I am having problems loading my software (Contiki) on the eval board STEVAL-IKR002V4. When connecting the board to my Windows7-PC with the USB-cable, that came with the board, it shows up as a COM-Port in the ...
JTAG Boundry scanning
Posted on October 31, 2014 at 13:34Hi:  I have never used JTAG but I understand it has a boundary scan feature that allows testing all the pins for shorts and opens. Also it is possible to JTAG test more than one part by 'daisy chaining' JTAG from ...
sanjib by Associate III
  • 1946 Views
  • 4 replies
USB Host FreeRTOS Assertion fails
Posted on October 31, 2014 at 20:02As soon as the USB disk is connected, I get an assertion fail, with this comment above this assertion:/* The following assertion will fail if a service routine (ISR) for an interrupt that has been assigned a priori...
  • 980 Views
  • 1 replies
How to connect clock crystal on STM32F427VIT?
Posted on November 02, 2014 at 20:14I am a newbie with ARM and ST parts, but I have used Microchip PIC parts for many years, though. Now I believe is the time to switch to a more powerful and expansive platform, so I am investigating ARM. I download...
bo by Associate
  • 1160 Views
  • 1 replies
stm32f407 - no cortex m sw device
Posted on October 31, 2014 at 14:43Hi, I'm a student starting to develop on my STM32F407 using uVision,I'm struggling on getting my board to link to my pc, I have installed the USB drivers but I still get the error ''no cortex M sw device'' from my ...
Where to report bugs in forum itself?
Posted on November 01, 2014 at 13:57Hi,This forum (seems to be based on MS-sharepoint) has a lot of bugs.For example, I can write new discussion only in Chrome and reply only on IE.When I write a new discussion or reply, I have always to select all ...
Osto by Senior
  • 1226 Views
