STM32 MCUs Products
Program execution stops during flash page erase
Posted on November 17, 2014 at 10:21Hi,There is an Audio-Codec connected by I2S to the STM32F407/401 with 48kHz. Every sample needs to be calculated as soon as it arrives to keep the latency between Analog In and Out as short as possible, which mean...
koster by Associate III
  • 1428 Views
Hard fault with stm32 std peripheral library
Posted on November 13, 2014 at 12:23Hi, This is a pretty noob question but I'm going to ask it anyway, because it seems like I'm missing something. I've just set up new STM32F1xx and STM32L1xx projects based on the GNU ARM plugin for eclipse.  I'm w...
Two questions about the A/D
Posted on November 13, 2013 at 17:31 Hi, I am successfully running most of my software, and I am now debugging the A/D. I first used the examples verbatim, to understand what I am setting up. I gave now modified the code, and have two questions: Th...
gullik by Associate II
  • 2306 Views
  • 5 replies
STM32F429 LCD and Images
Posted on November 14, 2014 at 03:46Hello everyoneCan someone explain to me in detail how to display an image on the touch screen? I have been looking for some kind of tutorial but I can't find any. I've been looking at the LCD_WriteBMP command, but...
stone by Associate II
  • 2975 Views
  • 3 replies
STM32F4 Disc - ADC sample time
Posted on November 14, 2014 at 15:10 Hi, I have this code, copied from anothers 3d in this forum, for a multi channel ADC: #include < stdio.h > #include < stdlib.h > #include < string.h > #include ''stm32f4xx.h'' //*******************...
pano by Associate II
  • 2179 Views
  • 5 replies
systick is stopped? while erasing flash memory
Posted on November 14, 2014 at 10:39On stm32f407, Erasing a 128KB flash sector takes about 1 second, but after I finished erasing 1 sector, the systick just happend for 3 times(3 milliseconds), as I config systick as 1000Hz.Does MCU disable systick ...
shark by Senior
  • 2369 Views
  • 5 replies
Bug Report STM32F10x_StdPeriph_Driver
Posted on November 14, 2014 at 18:14Hi, I'm just starting on ARM CORTEX and STM32 via The Spark Core so forgive me if I'm missing something but in file stm32f10x_tim.cFunctionvoidhttp://stm32.kosyak.info/doc/group___t_i_m___exported___functions.html...
julian23 by Associate
  • 1365 Views
  • 3 replies
configure gpio for external interrupt
Posted on November 14, 2014 at 14:53Hi I am using STM32F205 for my project (SN8000 EVK from  Murata).The SN8000 EVK uses Wiced SDK but it supports all the libraryfunctions, so the basic configurations will work(It uses vector tables in the vector_ta...
