STM32 MCUs Products
cmsis dsp library: fft length
Posted on November 24, 2014 at 13:22Hi, If i understand correctly using fft functions like http://mazsola.iit.uni-miskolc.hu/DATA/segedletek/arm/cmsis/CMSIS/Documentation/DSP/html/group___r_f_f_t___r_i_f_f_t.html#ga3df1766d230532bc068fc4ed69d0fcdc,...
teijo by Associate II
  • 1091 Views
  • 1 replies
STM32 RTC Alarm Not configuring
Posted on June 26, 2014 at 15:07Hi,I am using STM32l151vbt6 MCU and I am trying to configure RTC Alarm for ever 15th minute that is 0, 15, 30 and 45th minute of the every hour. I can configure the Alarm and it will work for the first time, If  I try...
Code explanation
Posted on November 21, 2014 at 16:01 Hi!  I would be glad if someone would explain the steps this code does in order to set up the AF9 on GPIOD for CAN pins. It is in a nice example, and I cannot figure it out why does the setting like this. void GP...
zamolan by Associate II
  • 1859 Views
Intermittant uploads via Serial bootloader
Posted on November 24, 2014 at 01:16First excuse this newbee post, as this question has probably been asked before, but I've not found an answer. I'm evaluating a several STMF103 based minimum development boards from eBay, and I'm getting a lot of p...
complete programming tools for linux
Posted on November 22, 2014 at 13:48hi every onewhat is best programming tools including compiler,maker,linker,ide &... in linux?i know maybe i cant find these integrated,then whats your suggestion for each part?i think to dont use any lite ,trial t...
mhdizgah by Associate II
  • 1662 Views
  • 8 replies
STM32F4-discovery httpsever
Posted on November 20, 2014 at 20:35Hello friends. Is there some example or resource of ethernet application for stm32f429-discovery? Where should I start to dig? Thanks.
baev_al by Associate III
  • 687 Views
Code size generation
Posted on November 21, 2014 at 18:47Hi all,I´m developing an application in Keil uVision with STM32L052C that is a uC that has 32KB of flash memory.I add my ST libraries and per example STM32L0xx_hal_uart.c. This library uses some features with DMA ...
gerardo by Associate II
  • 1159 Views
Pb generating 2 PMW
Posted on November 21, 2014 at 12:04The original post was too long to process during our migration. Please click on the attachment to read the original post.
franck2 by Associate II
  • 8116 Views
  • 22 replies
Locate Heap in SDRAM
Posted on November 20, 2014 at 15:39Hello, I have STM32f429 discovery board and I want to locate heap in SDRAM. SDRAM adress is 0xD0000000, size 0x800000. I use the Keil uvision 4. How to configure Keil and my code? #understand-your-tools #stm32...
z1060 by Associate II
  • 3087 Views
  • 5 replies
