STM32 MCUs Products
Resolved! Starting CAN Bus on STM32F302K8
Hi,I am working on STM32F302K8 and would like to use it's CAN Bus to communicate between devices both as master and slave It is my first time using STM32CubeIDE and the HAL library and implementing CAN Bus on my work. I did use some samples scattered...
Rey by Associate II
  • 4156 Views
  • 5 replies
  • 2 kudos
Resolved! STM32H755 Difference between M4 and M7
MPU:STM32H755XI6Connection with PC:USART1RTOS:ZephyrIn order to install Zephyr into STM32H755XIH6, if you build and burn images for M4 and M7, the M4 side will start but the M7 side will not.The content is LED flashing of PG10 (A9pin). Are there any ...
TDP_0000 by Associate II
  • 1668 Views
  • 1 kudos
STM32L011 USART2 and DMA (Continued)
Previous post: https://community.st.com/t5/stm32-mcus-embedded-software/dma-on-stm32l011f4/td-p/742092   I am working with code on the STM32L011 that uses DMA to read data from USART2.  I received excellent help on this forum before and I'm hoping fo...
Resolved! No Printf output on UART before \n
Good morning, I am trying to print a string on STM32F401RBT6 using vs code and Cmake, but I keep getting an issue, when I use '\n' the UART doesn't print nothing beyond the '\n', can somebody help me with this issue, please? printf("Hello\n World");
Gui_STM by Associate II
  • 3414 Views
  • 6 replies
  • 6 kudos
STM32G071G I2C bootloader
We used I2C bootloader for STM32G071GBU6N (UFQFPN28)  more than 3 years. We bought a new batch of controllers STM32G071GBU6N. Bootloader does not start. I tried to debug bootloader and if I stop program then old chip sets at the address 0x1FFF2128 bu...
Igor80 by Associate II
  • 5146 Views
  • 5 replies
ADC Multichannel Issue
I am using STM32F423RHT6 in my project. I am using 2 ADC Channels for measuring Voltage and Current(through Current Sensor). But I am facing a strange issue. Where the channel corresponding to the current is getting accurate values of analog voltage....
vbk22398 by Senior
  • 12366 Views
  • 10 replies
  • 2 kudos
Resolved! Strange issue with timer pwm in dma mode
Hello,I'm facing a very strange issue with timer PWM in DMA mode.I use the PWM channel to send step pulses to a stepping motor in order to free the mcu while the motor is moving, rather than using time consuming delays.The issue raises when I change ...
zeboss49 by Associate III
  • 2643 Views
  • 4 replies
