STM32 MCUs Products
STM32 USART can send but not receive on Putty
Posted on August 27, 2015 at 12:05Hi all, I'm very new to this so please bear with me.I'm using STM32L053 Nucleo and I set up normal polling USART to COM4 of the PC. I can send data to the serial monitor (PuTTy) but I can't receive anything back fro...
What is a CAN slave? (STM32F2xx)
Posted on August 27, 2015 at 09:52Hi, I want to design CAN as an option into a new project. While working with STM32CubeMX I get offered to use CAN1 as master or CAN2 as slave. Also ref manu says this. From my earlier experience with CAN I don't kno...
mmensch by Associate II
  • 2653 Views
  • 3 replies
input capture _ DMA request
Posted on August 25, 2015 at 15:59Hi,Please i have to capture an input signal  and read it's frequency value with a DMA request but i can't find any ressources.I know the other solution with interreupt but i insist on this method with DMA, i need it...
nechi by Associate III
  • 2304 Views
  • 5 replies
CubeMx missing I2C2 STM32F051C6Tx
Posted on August 27, 2015 at 09:50Hi , i'm currently developing a circuit with the STM32F051C6Tx. When i select the Cpu in CubeMx i can not selct the I2C2 on PB10/PB11, there is just the I2C1 on PB7/PB6. As i read in the Datasheet befor there have t...
Suggestion for USB MSC HOST on F7-Disco
Posted on August 03, 2015 at 18:25Hello,I'm building USB MSC HOST implementation library from stack provided in CubeF7 v1.1.0 series. I successfully fixed a bug with comparison for timeout and I got it working far quickly for first time.I took Appli...
tm3341 by Associate II
  • 1546 Views
  • 4 replies
WIFI STATCK for FREE RTOS IN STM32
Posted on August 20, 2015 at 08:26I am using FREE RTOS in my STM32 chip. Now i want use any modem which has SDIO interface for wifi functionality.Kindly let me know how to have wifi stack in FREE RTOS and how to do add particular driver for wifi dev...
punitb20 by Associate II
  • 3326 Views
  • 9 replies
USART problem on STM32L DISCOVERY
Posted on February 09, 2014 at 17:43Hi, I have a problem with the USART... basically i just want to sent out one integer (i will use a FTDI adapter to read it).  unfortunately my code get stuck to the instruction .while(USART_GetFlagStatus(USART1, U...
luca2 by Associate II
  • 2233 Views
  • 7 replies
