STM32F10x UART tx hyperterminal
nick2
Posted on March 24, 2015 at 14:45
I want to sent some characters to a hyperterminal program. But my program wont work..
I dont receive any characters in my hyperterminal.
I am using the STM32-P107 development kit. The controller on it is the STM32F107VC
I really need help here. I hope someone here see what i am doing wrong. I would really appreciate it.
This is my code:
#include ''stm32f10x.h''
#include ''stm32f10x_gpio.h''
#include ''stm32f10x_rcc.h''
#include ''stm32f10x_usart.h''
#include <stdio.h>
void USART_Print_Nick(void)
 int i;
//**************************************RCC Configuration*************************************\
 /* Enable GPIO clock */
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOC, ENABLE);
 /* Enable UART clock */
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
//**************************************GPIO Configuration*************************************\
 /* Configure USART Tx as alternate function push-pull */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;   // PA.02 USART1.TX
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
 /* Configure USART Rx as input floating */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; // PA.03 USART1.RX
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
 //LED TOGGLE.. initialized // PA.08 = output port for LED
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//**************************************USART Configuration*************************************\
 USART_InitTypeDef USART_InitStructure;
 USART_InitStructure.USART_BaudRate = 115200;
 USART_InitStructure.USART_WordLength = USART_WordLength_8b;
 USART_InitStructure.USART_StopBits = USART_StopBits_1;
 USART_InitStructure.USART_Parity = USART_Parity_No;
 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
 /* USART configuration */
 USART_Init(USART2, &USART_InitStructure);
 /* Enable the USART2 */
 USART_Cmd(USART2, ENABLE);
//******************************************Program**********************************************\
 while(1)
    // 1010.1010
    USART_SendData(USART2, 0xAA);
    //LED toggle
    GPIO_WriteBit(GPIOC, GPIO_Pin_8, 1);
       for(i=0;i<0x100000;i++);
    GPIO_WriteBit(GPIOC, GPIO_Pin_8, 0);
15 REPLIES 15
Posted on March 24, 2015 at 15:54
The USART is not compatible with RS232 levels, needs a converter.
You need to wait for TXE to assert before stuffing characters out.
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); // Wait for Empty
USART_SendData(USART2, 0x55); // Send Char
while(1) // Don't want to exit
uint16_t Data;
while(USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET); // Wait for Char
Data = USART_ReceiveData(USART2); // Collect Char
USART_SendData(USART2, Data); // Echo Char
nick2
Posted on March 25, 2015 at 08:43
It still dont work here. I really dont know what i am doing wrong. Could you look to my software one more time?
//*****************************************Includes*******************************************\
 #include <stdio.h>
//*****************************************Variabelen*****************************************\
 int i;
//**************************************GPIO Configuration************************************\
 //LED TOGGLE.. initialized // PC.08 = output port for LED
//  GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE); //nodig?
//**************************************USART Configuration***********************************\
 USART_InitStructure.USART_BaudRate = 9600;
//******************************************PROGRAM*******************************************\
   USART_SendData(USART2, 0x55); // Send char
francescatodiego
Posted on March 25, 2015 at 09:25
Add
 while (1) ;
tx only one 0x55 char _______________________________________
floating ? The Rx line is fixed externally ?
nick2
Posted on March 25, 2015 at 10:02
Thanks for answer man!
But still dont work :(
Or can you show me the complete software? I added the
while (1) ;
I just want to put every 50ms (or something) a char to my hyperterminal program to start. After that i will receive character etc. But for now just send every 50 ms a byte (in this case 0x55)
The software is now like this:
#include <stdio.h>
 int i;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);    //RCC_APB2Periph_AFIO
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;   // PA.02 USART2.TX
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; // PA.03 USART2.RX
 while (1);
nick2
Posted on March 25, 2015 at 10:06
francescatodiego
Posted on March 25, 2015 at 10:20
No !
powerup - config uart - send 0x55 - loop if nothing happen check cable connections Hyperterminal port and config if all ok Can you check the microcontroller tx pin signal ? Oscilloscope ? Logic analyzer ? As says clive have you used the level translator like MAX3232 (for 3.3Vdevice ) or MAX232 (for 5V device) ?
#include <
stdio.h
int i;
while (1);
nick2
Posted on March 25, 2015 at 10:47
Still nothing happens.
I got a other program from a coocox example and that works on USART 2, But now i want make my own USART program with the stm32f10x libary's but i cant get it work.
So the hardware is fine. but there is something in the software what is wrong.
So i hope you or someone else can see what i am doing wrong. ?
Thanks again for answer!
Posted on March 25, 2015 at 11:30
Do you have a debugger or scope, can you use those?
How is this function called? Is it called?
Where is main(), and does it call SystemInit() first?
Can you see any signal on the USART2_TX pin with a scope? Is it at the right baud rate or something else? If so what?
nick2
Posted on March 25, 2015 at 11:46
Hello thanks for answer!
Yes i have a debugger and scope. I measured at the Tx pin. I didn't see any signal on the scope (but i did with the coocox libray uart example. So hardware is tested well. With that program is also received characters at my hyperterminal program).
But now i want do it with the stm32f10x library's but i can't get it work.
I will show you my main.c and the function
void USART_Print(void);
int main(void)
SystemInit();
    //automatically added by CoIDE
USART_Print_Nick();
#include <stdio.h>
 int i;
 int y = 0xAA;
 while (1)
USART_SendData(USART2, y); // Send char
