STM32 MCUs Products
TIMx_OCrefClear (stm32F30x)
Posted on April 19, 2016 at 21:39Hello All: I am tearing my hair out trying to get cycle-by-cycle PWM control working on the Stm32F303RE using the OCRrefClear signal from the comparators.   PWM working on complimentary channels  (check). COMP works...
STM32F1 SPI communication with L3GD20 gyro
Posted on April 21, 2016 at 14:57Hello everyone!I currently working on my masters work with STM32F1 MCU. I created work in STM32Cube - SPI2 communication protocol with gyro, UART communication protocol to PC. And everything was fine until I wanna wr...
erase is not working in my board!!!
Posted on April 20, 2016 at 22:40Hello everyone,I'm developing a code in STM32F407VG. this code will erase the flash memory in a first step, and for a further work will upload a code into this memory.this is my code for erasing the flash memory.//un...
ouled by Associate
  • 1052 Views
  • 1 replies
stm32f429 discovery dfu problem
Posted on April 21, 2016 at 12:19Hi,I want to use bootloader from usb with stm32f429 discovery board. I have pull down the BOOT0 pin and pull up the BOOT1(PB2) pin. I have connected the boards to copmuter from usb connectors (from mini and micro usb...
er3481 by Senior
  • 913 Views
I2C checkevent hang
Posted on April 21, 2016 at 08:51Hi all,I am writing a program on the STM32F446 in which I am trying to talk with a PCM sound module via I2C. I am attempting to read its registers, which involves sending the register number and then reading the valu...
luke2 by Associate II
  • 787 Views
  • 0 replies
STM32Foxx CRC: usage of HAL Drivers
Posted on April 15, 2016 at 14:34I want to make the CRC progress as soon as I receive bytes so I want to calculate partial CRCs as soon as the packet is entering the system. Should I use HAL_CRC_Accumulate with buffer size =1?I also deal with bytes ...
stanzanim by Associate III
  • 6070 Views
  • 11 replies
