STM32 MCUs Products
STM32F746, ADC
Posted on July 25, 2016 at 12:05 Hello, I have a few question about ADC. I want to drive ADC through DMA. The problem is that when I choose more than 6 samples I cannot enter in HAL_ADC_ConvCpltCallback. My second question is how to set the time...
STm32CubeMX code generation bug
Posted on August 31, 2016 at 16:09 Hi, I started a brand new project in STM32CubeMX, picked STM32F427ZIT6 MCU, selected SW4STM32 toolchain. Code generation settings not changed, left to default ''Copy only the necessary files'', ''Keep us...
dman by Associate II
  • 1099 Views
  • 1 replies
Searching for an compatible Crystal
Posted on August 02, 2016 at 11:51I want to develop a PCB with a STM32F4 by my own. And I am searching for compatible Crystal.During my research I looked at the values of the Crystal on the STM32F429I-EVAL Board and a now I�m a little confused.Becau...
mfrank9 by Associate III
  • 869 Views
  • 1 replies
ST virtual com port issue in case of MCU reset
Posted on February 22, 2014 at 17:03I have a problem with serial-over-USB port reconnection after stm32f4discovery board reset (for instance, re-programming) - with the native USB controller port, not the uart dongles. I have originally reported thi...
arro239 by Senior
  • 6336 Views
  • 14 replies
How to generate a DC level on STM32F4 DAC?
Posted on August 30, 2016 at 03:56Hi, I am using pin PA4 as a DAC output on an STM32F405. I then have a unity gain op-amp buffer. My supply is 3.3V. What I want to do is rather than create a SINE output at some frequency, is to generate a DC signal....
