STM32 MCUs Products
STM32L4 RTC Accuracy
Posted on March 27, 2017 at 10:31Good morning,I'm developing an application based on STM32L475 device.I use the RTC (LSE based) as a periodic wakeup source, as application is periodically going to Stop2 mode: I have followed the '...STM32Cube_FW_L4_...
Solution for firmware updade
Posted on March 22, 2017 at 14:31Hi ,I would like to know if ST offers a ready solution for a Safe (not secure) firmware update , in this case the main problem is the safety of the firmware update procedure itself and the problems/incidents that cou...
Understanding ADC Accuracy
Posted on March 26, 2017 at 18:56I am looking to determine the accuracy of a sensor using the ADC on an STM32L0. For reference, the datasheet's specified accuracy is here: https://i.imgur.com/Q1w9Eq5.png  . The sensor outputs a voltage in relation t...
how to read multi channel ADC value
Posted on December 18, 2016 at 08:27hi,  i want read multiple ADC value .for this i am using  1)STM32f030f4p6tr core2)STM32 cube mx 3)keil u vision 5 in my project i want read 3 different sensor value using ADC. for this project i used DMA  but DMA ...
Bi-Directional Motor Control using PWM in STM32F1
Posted on March 27, 2017 at 07:46Hello everyone,I am trying to reverse the motor direction using PWM from the STM32F1 Series controller and using the L293D Motor driver. I have referred to the bi-directional motor control circuit given in l293d data...
how to make default high SPI MOSI signal of STM32F401
Posted on November 25, 2016 at 14:56 Hi,      We are using STM32F401 MCU, definition of SPI1 Initialisation function/api is  attached, we need to make MOSI signal to be high (default it should be high), if no communation between master and slave.ple...
Kris1 by Associate II
  • 6773 Views
  • 8 replies
STM32F CAN messages filtering
Posted on March 23, 2017 at 11:40Hello,I would like to ask you for an advice regarding the CAN messagesfiltering. I am not sure whether I understand the filtering and maskingin right manner. I have following settingsCAN_FilterConfTypeDef filt;filt.F...
Resolved! STM32F205 SPI data register always zero, as master
Posted on March 24, 2017 at 17:58 Hi, I'm semi experienced with STM32, have been doing a lot of things. This issue is totally new to me: I'm trying the simplest thing ever, basic SPI, set as master, chip select managed by myself. Transmit works, c...
