STM32 MCUs Products
Tutorial of SPL2LL converter
Posted on July 17, 2017 at 15:49Hello ,  It's a good news , ST finaly develop a application to migrate from SPL to LL ,there's any tutorial please , how to use this convertor , what's the exeption .... Best regards #migrate #migrate-from-stmf4-to-st...
Resolved! STM32U5 HSE Crystal
I'm currently at schematic stage designing a board based around the STM32U5G9ZJT6Q. The PCB will be produced and assembled by JLCPCB, so I had a look for a HSE crystal they have in stock and found this:https://jlcpcb.com/partdetail/YangxingTech-X3225...
AMars.4 by Associate III
  • 1530 Views
  • 3 replies
  • 2 kudos
Read Protection level 1
When I tried to enable read protection level 1 through STM32Cube Programmer(using ST link and J link), I was able to do so successfully. However, after enabling read protection, none of the peripherals worked properly—specifically, the push button an...
kRaje.1 by Associate II
  • 2623 Views
  • 5 replies
Resolved! STM32H7 GPIO control by both M4 and M7
Hello,I have a GPIO pin that is owned and used by the M4, i.e. Pin Context Assignment.  But on power-up, I'd like the M7 to do some work with it, toggle the state, before it starts the M4.  Is it possible for the M7 to programmatically take ownership...
R_DSP by Associate II
  • 1121 Views
  • 1 kudos
SPI Master, Slave Issue
Dear ST Team,I am currently working with the STM32F407 board and implementing SPI communication between a Master and a slave. While the slave does respond to data sent by the Master, I am encountering an issue where the received data sometimes rolls ...
PSSI DMA or IT on STM32H5?
Hello!I have not been able to figure out how to get PSSI DMA working for the H5. For other peripherals, there is a DMA-tab in the configuration, but not for PSSI. Similarly, I have not been able to find any way of using interrupts for transmitting or...
olaan by Associate II
  • 5648 Views
  • 10 replies
  • 1 kudos
