STM32 MCUs Products
Assert issue due to PLLR parameter
Posted on April 19, 2017 at 17:48Using CubeMX 4.20.1 with STM32Cube_FW_F7_V1.6.1 on an STM32F777 I'm getting an assert in HAL_RCC_OscConfig() due to assert_param(IS_RCC_PLLR_VALUE(RCC_OscInitStruct->PLL.PLLR));Was this supposed to have been fixed in...
MXCube Generate STM32F031 SPI Slave miss BaudRate Field
Posted on March 02, 2018 at 10:59I used MXcube to generate initiaation code as SPI Slave, CHPA is hope to be Low.But it will be set when the LL_SPI_Init(SPI1, &SPI_InitStruct) function is running.I found that Miss BaudRate Field.  It can probably in...
Wang Jun by Associate
  • 593 Views
  • 0 replies
I2C speed on STM32F303KT8
Posted on March 01, 2018 at 22:25Hi everybody, I would require some help on an I2C link between TSL2591 and my nucleo nano F303K8T6.I did it working well  on the mbed website TSL2591_F3, but I want to use SW4STM32 environment and also CUBEMX.Using m...
baptor by Associate III
  • 1828 Views
  • 3 replies
STM32F031 SPI Slave can not send out CRC Correctly
Posted on March 02, 2018 at 09:52STM32F031  is configurated as SPI Slave, CRC result can not be send out correctly. Attached the whole project. I also designed one SPI master by another STM32F031 for this testing. The waveform that master sent is ri...
  • 725 Views
  • 0 replies
Resolved! I can't download the library from ST's website
Posted on May 06, 2017 at 00:19Hello,I have been trying to download the library for CLASSB certification for STM32's but i can't manage to download it.http://www.st.com/en/embedded-software/x-cube-classb.html I tried to press request software and fi...
Refinement about DMA
Posted on February 28, 2018 at 12:55I have a few misunderstandings about DMA, so I need some help. I setup DMA to copy from GPIO IDR (without inc) to sram (with inc), it triggered from Timer (Free Running, Overflow event).In the case of algorithm li...
Roman K by Associate II
  • 4459 Views
  • 10 replies
STM32L431VCT6
Posted on March 01, 2018 at 12:34Dear Sir,We are using STM32L431VCT6 in our design.I want to know how to configure USART to UART ?
srr r by Associate II
  • 1791 Views
  • 3 replies
