STM32 MCUs Products
STM32L4: Issue writing flash memory
Posted on June 13, 2018 at 02:52Greetings,    I have a program that is writing flash memory.  Everything is working fine, except for some reason the last 16 bytes of each page refuses to accept a write.  Every other location has no problem.  I don't...
STM32F070 SPI NSS
Posted on June 13, 2018 at 21:42Hi,I am trying to get the hardware to control the NSS line on a SPI bus but it is not cooperating. I am talking to a DAC that requires 16 bits per transmission and 4 transmissions because its a quad DAC. The NSS line ...
Reliability data needed for LPS22HB and STM32L151
Posted on June 12, 2018 at 19:32I want to know the reliability data about the pressure sensor and the microcontroller:LPS22HBSTM32L151 I'm interested in the data like operating life or MTBF. The working environment for the sensor will be:20°C, 1 at...
Timeouts in micro seconds
Posted on May 24, 2018 at 18:22Hi All,I'm using:STM32H7xxTIM4HAL_TIM_PWM_ConfigChannelHAL_TIM_PWM_Start_ITHAL_TIM_PWM_InitI'm tring to use the general timer and its channels to generate 4 sources for timeouts.The timer is feed by a 200MHz clock and ...
STM32CubeMX can change speed clock at ruining time
Posted on June 13, 2018 at 16:36I need your suggestion about low energ, generate code by Stm32CubeMXBy in my project want to change speed clock at run time== I have a question ==I can change speed clock at ruining time?   - If possible, How can I do...
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
