STM32 MCUs Products
How to put device into shutdown mode? STM32L4R5ZI
I am trying to modify the example given for neucleo - LP14R5ZI and port for my custom board.User button in example is similar to PA0 in my codeand similarly for LEDThe device does not go into shutdown mode. I have attached main.c of my modified code
VPuro by Associate
  • 1171 Views
  • 1 replies
Resolved! STM32F746 QSPI: problem with Flash ROM(Winbond W25Q16JV)
I have a problem with QSPI. I try everything, but program doesn't work.I am using STM32F746 series MCU and I am trying to interface with a quad spi memory from Winbond (W25Q16JV).I am following the example found in this location:(I modified some inte...
KNono by Associate II
  • 7312 Views
  • 4 replies
CAN bus does not work
Hello,I am using the STM32F7 in my project, which uses the CAN1. I create the project from cubemx and connect it to a STM32F4 evaluation board to test. I can see the Can signal via the oscillations cope after the transceiver, but no interrupt can be ...
kqian by Associate II
  • 2897 Views
UART stm32F767ZI
Hello everybody,i wanted to send data from realterm serial to the stm32F767ZI but it dose not work. i cant see any message on my terminal. The same code is working good with STMF446re. The UART2 with STM32F4446re is connected to the USB Port. but wit...
Samuel1 by Associate III
  • 3188 Views
  • 3 replies
