STM32 MCUs Products
MIPI-DSI on STM32U5G9 - how to get started?
Today I tried to configure MIPI-DSI on STM32U5G9 using CubeMX and I did not win this first clash.MX_DSIHOST_DSI_Init() function fails executing HAL_DSI_Init() where it waits for DSI_PSR register flags PSS0, PSS1 and PSSC to be set (indicate both lane...
TDJ by Lead
  • 2377 Views
  • 1 kudos
Powering Nucleo-144 through E5V
Hi!I designed a shield for the Nucleo-144 (F429ZI) which provides power to the Nucleo-144 board through the E5V pin.To configure the board, I did the following:Place JP3 E5VRemove JP1Remove JP6Remove JP7Open SB169Close SB115I disconnected the ST Link...
niels.d by Associate
  • 2802 Views
  • 3 replies
Resolved! CAN in Normal Mode with STM32F407 microcontroller
Hello everyone, I'm trying to switch from loopback mode to normal mode. So the program is working perfectly in loopback mode but i had to adapt it so i can use it in the desired normal mode. I switched to the HSE as a source clock for CAN communicati...
Azizz by Associate III
  • 1326 Views
  • 1 replies
OPAMP1 as follower don't give expected results
I'm trying to use OPAMP1 on stm32g431 adapted by WeActStudio (https://github.com/WeActStudio/WeActStudio.STM32G431CoreBoard)My Cube settings: Scoping on generated voltage going to PA1 show 2V:Scoping Vout on PA2 showing 0V instead of 2V:I've only the...
Sercurio by Associate
  • 1012 Views
  • 1 replies
