STM32 MCUs Products
nuttx RTOS build
Posted on October 15, 2014 at 09:49hi every body , i decided to use nuttx for my rtos. now i have a problem to understand it, i cannot build it , and i don't know how to use it in an IDE like eclipse . have any body used this rtos ??thanks
How can we integrate continuous data(Real time data)
Hello.I am estimating SOC using coulomb counting method.By coulomb counting method ,we have to do integration of discharge current.I got successfully discharge current in a variable but it shows one value at a time.I know,by using array we can store ...
Mohan1 by Associate III
  • 2343 Views
  • 5 replies
STM32F417 RTC_BKPXR Reset during power up
The RTC_BKPXR register is for recording power off status in our board, we make 10 boards, 4 boards works and 6 boards keep reset the RTC_BKPXR during power recycle, I check the Vbat, it is 2.91 Volt after power off which is correct.I use TureStudio t...
STM32 UART Baremetal
Hey guys, I've been playing around with STM32F334R8 Nucleo board's USART module. As a part of it, I have written a small bare-metal code to print a character and unfortunately, my code isn't working. I am seeing junk on my putty window sometimes and ...
HWin.1 by Associate
  • 2574 Views
  • 7 replies
STM32H745-DISCO odd SDRAM problem
Hi all,my SDRAM setup seems to work EXCEPT that I have a strange behavior:When I write any value (8, 16, 32 bit) to an address (example 0xd000004),it in fact gets written to the address - 2, in this example 0xd0000002.All written bytes are readably @...
LHohl.1 by Associate II
  • 2006 Views
  • 3 replies
ADC multichannel question
Hi, I want to set 3 channels of adc and transfer data via dma to buffer.​But I want to read rando​mly, sometimes only ch1, sometimes only ch3 etc. One channel at time. And fill buffer with data from one channel.​​Do I have to set:-adc continous - dis...
oeliks by Senior
  • 1000 Views
