STM32 MCUs Products
Watchdog doesn't fire while hanging in I2C
Hi,I have a situation where the configured watchdog on my STM32L031 does not trigger even though the MCU gets stuck in an I2C function. In my program flow, I first run through some initializations (as well as I2C_Init()) and then start the IWDG (Star...
Brigei by Associate III
  • 1748 Views
  • 12 replies
  • 4 kudos
STM32H735 Wake Up pull configuration STANDBY mode
I am configuring wakeup pin PA0 to WAKEUP1 by wirting 01 (pull-up) at WKUPPUPD (PWR_KUPEPR) as said at RefManual by using "HAL_PWREx_EnableWakeUpPin ".   PWREx_WakeupPinTypeDef sPinParams; sPinParams.PinPolarity = PWR_PIN_POLARITY_LOW; sPinParams.P...
amartin by Associate II
  • 1217 Views
  • 3 replies
Resolved! No OSC_IN on STM32H503KB (32-pin QFN)
The 32-pin package doesn't seem to have any kind of external clock input at all, and the device does not feature "crystal-less USB". How do we provide a stable clock for USB then?
maxter by Associate II
  • 8975 Views
  • 1 replies
  • 2 kudos
STM32U031R8 Current consumption is too high
Greetings,I have acquired Nucleo-U031R8 as I was searching for ULP controllers and specification of this one was good. I am currently trying to lower current consumption as low as possible. Previously, I have used Nucleo-L073RZ where I was able to ac...
JeetS by Associate II
  • 2132 Views
  • 7 replies
MicroSecond Delay in FreeRTOS
I am dealing with an I2C lockup issue where the I2C bus is locked up periodically and I need to toggle the SCL pin to free up the bus.  To test my theory and make sure that the fix works I just used an osDelay(1) call.  I know this is a 1ms delay but...
