STM32 MCUs Products
Resolved! STM32G0 internal temperature invalid readout
Hello,For some reason I'm unable to get valid readout of internal MCU temperature. Maybe someone have an ide why this might be happening? System is running on STM32G0B0 MCU. I init ADC over HAL generated code and enable only internal inputs (`ADC_CHA...
lauris by Associate III
  • 2114 Views
  • 6 replies
  • 3 kudos
Resolved! STM32 Learning Path
Dear Team,I am completely new to Embedded systems.I am an analog design engineer.Decided to start my embedded learning with STM32.I bought  a nucleo-64 board.If you don't mind could you please guide me how do I start. I saw many training materials in...
Hariom by Associate III
  • 994 Views
  • 1 replies
  • 1 kudos
STM32U575 System Bootloader SPI MISO issue
I am evaluating using SPI and ST's internal System Bootloader for a 2 processor application.To that end, I am attempting to attempt to read in the bootloader via SPI on an STLink V3.I am successfully able to do so for a NUCLEO-L496ZG, but fails for a...
i2s_ckin vs. PLLI2S
Hi,I'm using an STM32C051K6T6 to read an audio file from FLASH (a book on tape, basically) and output the data over I2S to a codec/amplifier. I would like to understand the drawbacks, if any, of using the internally generated PLLI2SCLK instead of an ...
how to interface 50 pin lvds 1920*720 in f769-dis0
Hi ST-Members,I need to interface a 10.3-inch LVDS display with a resolution of 1920x720 to an STM32F769-disc0. I also have an H743 Nucleo board. Could you please advise on the method I should use to make the display work? Additionally, I plan to ini...
mbed_engr by Associate II
  • 3025 Views
  • 1 replies
