STM32 MCUs Products
I have a problem with configuration the TIM1-ETR in stm32f1
I want to use the external clock mode 2 but it dose not work ,configure the PA12 that connect to TIM1-ETR AND make push button pull down to send pulses to that pin(PA12) to detect high edge and make up count to the variable "upCount" in the code ,i t...
HSale.1 by Associate
  • 1374 Views
  • 0 replies
STM32H7 - Handling with 2 MPUs
Hello, the STM32H7 (dual core) has two dedicated memory protection units. If I configure one MPU to make a memory region only accessable as readonly, does the memory protection unit from the other core inherit those configuration or is it bypassing ...
PButc.1 by Associate II
  • 3587 Views
  • 6 replies
STM32G4 ADC Errata
Hello,For STM32G4 Rev Y:Errata 2.7.3Wrong ADC result if conversion done late after calibration or previous conversion DescriptionThe result of an ADC conversion done more than 1 ms later than the previous ADC conversion or ADC calibration might be in...
JVinc.1 by Associate III
  • 2789 Views
  • 1 kudos
