STM32 MCUs Products
Simple write to flash memory address ... no fault? nothing?
Does doing a simple write to the flash address space not result in any kind of a BusFault or other error interrupt?After debugging an issue wherein I did not realize that I was running `qsort` on const data that was residing in the, I was a little su...
apullin by Associate II
  • 2012 Views
I am trying to find the correct code to authenticate a file transfer to AWS S3 using aws-iot-device-sdk-embedded-c from GitHub but cannot find the correct embedded C code to use in my STM32CubeIDE project. Doe anyone have any hints or tips?
I have looked through the SDK mentioned above but I need code in embedded C that I can use in my STM32CubeIDE but cannot find it. The code needs to follow the flow shown in the attached file.Do anyone know how I should go about doing this and what c...
MHarr.8 by Associate II
  • 911 Views
  • 0 replies
STM32 MCU stack analysis
STM32F469NI controller and IDE System workbench version 4.5.2 MCU with 2MB flash and 320kb RAM are used. for LCD ST emWin graphic library with GUI interface we using.The problem is that we are updated new touch driver code. The touch is detected, bu...
MRedd.3 by Associate II
  • 6009 Views
Resolved! What the square brackets mean in the pinout?
Hello, I am still learning about STM32 and I know that the slashes mean that several ports are bonded to the same pin (e.g. PB7/PB8), but what the square brackets mean in a STM32 pinout? and the dash? thanksBest regards
Tommino by Senior
  • 1621 Views
  • 4 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
