STM32 MCUs Products
Enquiry on MCU Availability and its Technical document
I am Sudhakar from Rennova solutions Hosur. We have a plan to design 1kW CC-CV OFF BOARD CHARGER for TWO-WHEELER. I found an application note AN4856 using MCU STM32F334C8. If ST have any design tool/worksheet for 1kw. Can you suggest a suitable MCU ...
Sp.1 by Associate
  • 693 Views
  • 0 replies
Resolved! I2C using DMA intermittently stalls
Hi All,I have a STM32H7 master communicating with I2C to 4 STM32F0 slaves. The I2C uses DMA but intermittently stalls when the master is transmitting to a slave. It sends the address and the first data byte successfully (acknowledged), but then fai...
DOsbo by Senior
  • 2067 Views
Resolved! STM32L432KC ADC DMA channel dependecy problem
Hello,I am trying to get information from two analog sensore (FSRs) by using two seperated data lines (PB0 as IN15 and PA7 as IN12) through ADC1(Not important note - I created unint32s for debuging and I am willing to transfer the data by using CANBU...
RKavod by Associate II
  • 6526 Views
  • 10 replies
Resolved! STM32H723ZG ADC with DMA
Hello everyone,I am using an STM32H723ZG MCU and wanted to use ADC scan conversion with DMA. I could implement what I wanted there is just one thing I do not fully understand related to it.I am using ADC3 whose maximal resolution is 12 bit. Based on ...
GVG by Associate II
  • 9230 Views
  • 8 replies
Resolved! FLASH_WaitLastOperation and FLASH_SR_PGSERR
Hi all,I'm trying to write in the internal flash memory of my new MCU (STM32L496VGYXP),but FLASH_WaitLastOperation fails. The error seems to be FLASH_SR_PGSERR .I'm sure that my code used to write flash memory is correct because in others projects it...
M4R10 by Associate III
  • 3945 Views
  • 4 replies
