STM32 MCUs Products
Resolved! Error in STM32F769 Reference manual RM0410 Rev4
Hello there,recently I have found an error in the reference manual RM0410.On page 1546 in figure 503 Filtering mechanism - example it is Identifier #4, which matches the recevied message. However, in the description below it said Identifier #2. I don...
JPan.4 by Associate III
  • 1038 Views
  • 1 kudos
Resolved! Noise in the open colector output
Hello guys, I have a problem with my project. I'm development the PS/2 (device, keyboard-like) protocol with my STM32F103C8T6 (Bluepill). When i convert my port to the open collector output, the noise appear in the PS/2 bus. In this moment, the STM32...
STM32U585 - Wakeup reason detection when exiting shutdown
Hi, Im trying to get WUP reason after the MCU exited the shutdown. I'm using pushbutton connected to PC5 pin to wake up the MCU. I cannot get the WUP flag to behave correctly. Sometimes it is present, sometimes not. This feature is part of bigger pro...
DHečk.1 by Associate
  • 2030 Views
  • 4 replies
I am trying to simply turn PA0 HI on an STM32F030F4P6 using Cube IDE. No matter what I do, if I try to write to any GPIO registers (including using the auto generated Inits), I get a Hard Fault. Nothing solves it :(
I am trying to simply turn PA0 HI on an STM32F030F4P6 using Cube IDE.No matter what I do, if I try to write to any GPIO registers (including using the auto generated Inits), I get a Hard Fault. Nothing solves it :( Tried debugging it, no matter what...
BBrow.2 by Associate III
  • 6738 Views
  • 18 replies
STM32G0x1 Alternate Functions Clarification
I am designing a board and would like to use the 32 bit timer (TIM2) in encoder mode. Per the block diagram in RM0444:the inputs to the encoder interface are T1FP1 and TI2FP2, which originate from TIM2_CH1 and TIM2_CH2 (highlighted in yellow). It a...
SHobb.1 by Associate III
  • 4818 Views
  • 7 replies
How to stop and then re-start one-shot timer?
I am working on the STM32L4S9AII6 MCU. I have timer 6 configured in 1 shot count up mode. Interrupt is enabled. How do I stop a one-shot timer that is already running? I've tried a bunch of things but no matter what I do I can't get the timer to work...
0693W00000WLMEFQA5.png 0693W00000WLMFwQAP.png 0693W00000WLMGQQA5.png 0693W00000WLMGfQAP.png
MFolk.1 by Senior
  • 9347 Views
X-NUCLEO-IDB05A2 not working, stuck on SPI_Reset on STM32F746ZG
Hi all, hope all is well. I've been trying to learn the STM32 by creating a project for myself, and I am stuck on the bluetooth portion of things. I have watched videos, read documentation, etc, and I just don't know where I'm going wrong. I've been ...
TC2 by Associate II
  • 3848 Views
  • 6 replies
