STM32 MCUs Products
Functional safety
Hello,I would like to receive the UL(E480533) condition of acceptability what is the failures in the internal watchdog? is external watchdog is needed ?Do you have risk assessment for STM32F ? can you share it?can you recommend a consulting company t...
yeila.1 by Associate
  • 1029 Views
  • 1 replies
Higher priority timer will preempt lower priority external interrupt, but will not preempt a lower priority timer.
EDIT: Hello, everyone. My code issue seems to have resolved itself after much changing, but I never did find out what was happening. My real question was answered: There are no likely circumstances that a higher-priority interrupt should not pre-e...
Charles P by Associate II
  • 7616 Views
  • 14 replies
I2C communication address issue
Hi, All. I have come across an odd situation in I2C communication between F405 and sensors1) F405 is master. address is 7 Bit2) with 3 slave I2C sensors , address, 22h,35h,78h3) There is no issue to read data from sensors of 22h and 35hbut when comm...
_legacyfs_online_stmicro_images_0693W00000bkmxQQAQ.png _legacyfs_online_stmicro_images_0693W00000bkmxaQAA.png
Forest.Xu by Associate II
  • 2253 Views
  • 3 replies
Resolved! Making a UART frame from ADC value WITH ASCII Control Character
Hello,My aim is to send (from my nucleo board_F103+FTDI) somes ADC value from DMA.Easy...But i would like a frame like that (Windows Software need it):<STX>ADC1;ADC2;ADC3<ETX><CR><LF>I'm able to send data, no more...uint16_t sensor_B =1234; char str[...
jlecl.1 by Associate III
  • 1736 Views
Resolved! Data transmit by UARD (DMA) with junk character
Dear eveyone,I' little confuse..I'm trying to send dat over uart from a nucleo board (F103 + FDTI). If a use "normal"method, it's work great.I mean, i receive "1234567890" WITH a new line.uint8_t start [20]= "1234567890 \n\r"; HAL_UART_Transmit(&huar...
  • 2396 Views
  • 4 replies
