STM32 MCUs Products
Can't receive any CAN data on STM32F303CCT6
Hello I tried to receive any CAN signal on my device based on STM32F303CCT6. Maybe you have solution :), CAN pins are remapped on PB9 and PB8 pins by STMCubeMX configuratorBelow my code (main.c): https://pastecode.io/s/7av2ge6mand my settings in con...
_legacyfs_online_stmicro_images_0693W00000dDdRcQAK.png _legacyfs_online_stmicro_images_0693W00000dDdRhQAK.png _legacyfs_online_stmicro_images_0693W00000dDdRmQAK.png
MSzła.1 by Associate III
  • 1105 Views
  • 0 replies
Resolved! STM32F302VCT6 - PC13 -> RTC_OUT_CALIB ?
I would like to set a 1Hz signal on the PC13 (RTC_OUT_CALIB). I have found a manual in document AN3371 (see picture in appendix). The code is also in the appendix. Unfortunately, nothing happens on the PC13 but the RTC works. If anyone has any idea w...
_legacyfs_online_stmicro_images_0693W00000dDc1sQAC.png _legacyfs_online_stmicro_images_0693W00000dDbR2QAK.png
KHabe.1 by Associate II
  • 3489 Views
  • 5 replies
Upgrading CubeIDE1.9 to 1.12
I created many projects using CubeIDE1.9. I now installed CubeIDE1.12 and need to open my projects in the new version. I copied my old projects to a new workspace I created and then tried to import/open projects using CubeIDE1.12 but got a generic...
LMorr.3 by Senior II
  • 1129 Views
  • 3 replies
how to connect more than 2 chips over I2C ?
I have custom board with 4 chips, communicating over I2C. The problem is that I cannot have 4 chips talking to each other.I can only communicate between 2 chips. As soon as I enable I2C on third chips the communication stops. One is setup as master t...
MNapi by Senior III
  • 1456 Views
