STM32 MCUs Products
Resolved! SPI troubles
Hi - I have a new board with very minimal parts other than a STM32L451VET6 micro and a SPI LCD.I have implemented SPI and the micro is sending data when I single step the program. When I just let it run it Sends exactly three and one half bytes... ev...
Stoufer by Associate III
  • 2286 Views
  • 4 replies
  • 1 kudos
Uboot failed when "Saving Environment to MMC..."
Hi,we have an image, install on few SD cards. Most of them boots just fine, but few of them get stuck at  "Saving Environment to MMC...".I tried to reduce the SD clock to 25, 12.5MHz but it doesn't help. Does anyone know where the point to investigat...
Dat Tran by Senior II
  • 1130 Views
  • 0 replies
Resolved! STM32 mcu finder
HiSTM32 mcu finder for iPhone is fine.But, STM32 mcu finder for iPad is stuck with a component database dated Jul 14, 2021 20h18.It's a way to have an updated database ?Thanks in advance
How to generate PWM using timers working with PLL
Here, i am working on STM32F401 controller, where i am using PLL with HSI working at 72MHz freq. The timer is generating a PWM output but instead of generating 24 pulses as per my requirement it is only generating 6 pulses. Hence 2 pulses for every 8...
DJ1 by Associate III
  • 2984 Views
  • 4 replies
ADC
I want to read  voltage of an  analog waveform  of 1khz after 50us of every rising edge and skip other reading of every cycle how to configure adc in stm32 if anyone have code for this please help..
ishu by Associate II
  • 1427 Views
  • 1 replies
