STM32 MCUs Products
Accessing SD card via SPI
Posted on January 03, 2013 at 05:55Hi, I have an STM32F4 discovery board and I want to access SD card via SPI. The reason why I want to access Sd card via SPI is that the breakout module that I have has an SPI interface. I have looked on the interne...
osama by Associate II
  • 1201 Views
  • 1 replies
stm32f407, jtag does not respond
Posted on January 02, 2013 at 23:09Hi all,I have a strange behaviour with 4 stm32f407 boards related to the jtag. The jtag of the stm32f4 is connected to a FTDI4232 chip. I have connected only the JTCK (with a 10k pd), the JTDI (with a 10k pu), the ...
romaine by Associate II
  • 1473 Views
STM32 F103xx using PB3
Posted on September 20, 2012 at 11:44Hello, We want to use PB3 of the microC. As found in some forums we have to disable JTAG. We do this using following line of code: GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE); Then we want to use P...
gino by Associate II
  • 3594 Views
  • 7 replies
Hard Fault Handler Interrupt Stm32F1?
Posted on January 02, 2013 at 21:55Any help with finding this bug is appreciated. I am truly at a loss.I am using the virtual com port for USB(V.3.1). I had it working great, communication was like a wife and husband once wished. I was sending host ...
STM32F0 ADC DMA, where are results of measurements
Posted on December 28, 2012 at 09:21Board STM32F0 Discovery, measurment on 4 analog inputs: PC0 - ADC_IN10 PC1 - ADC_IN11 PC2 - ADC_IN12 PC3 - ADC_IN13 and Vbat, Vref, Vtemp. Configuration of ADC1 and DMA is shown in attachment. for ''ADC_InitStruct...
STM32F4 ADC_TripleMode_RegSimult
Posted on December 20, 2012 at 17:27Hi, I am trying to use the 3 ADC in simultaneous mode. I receive correctly every data but I am not able to catch any interruption in order to drive data on the good place. When I have my table I want to dispatch a...
yayi by Associate II
  • 6179 Views
  • 18 replies
ADC in STM32F4 Discovery
Posted on January 02, 2013 at 08:06hi:     i found that ADC12 and ADC123 in STM32F4 Discovery.  How Can I use them?    or whats the way to use ADC on STM32F4Discovery? I have library of STM32F4xx.c in that ADC1, ADC2, ADC3 are only defined? which ar...
its by Associate II
  • 1386 Views
  • 1 replies
Problem on using USART with DMA
Posted on January 01, 2013 at 20:52Hello, I am implementing a UART driver using circular queue scheme, and found a minor problem with it. When I put a new character after DMA channel 5 finishes its transfer - i.e. put a new character when DMA_CNDTR5...
how to use Index Track in quadrature encoder mode
Posted on December 26, 2012 at 18:15have 2 timer channels (CH1+CH2) setup in quadrature encoder mode and all things work fine. The encoder (Avago HEDS 5540) has a third index channel with very narrow pulse per revolution. Is ist possible to use this...
jveith by Associate II
  • 2959 Views
  • 3 replies
