STM32 MCUs Products
help STM32-P103 RS232
Posted on March 25, 2013 at 22:18Hi i would like to use the circuit MAX3232 (RS232 adapter) to connect two PORT RS232 with this circuit using just TX and RX onlyif possible this experience?????and thank you
USB code in STM32F103 for HID application
Posted on March 26, 2013 at 00:18Hello,  I have USB problem with my application with this uc. Your User manual UM0551 ''USBHID demonstrator'' would be useful and thanks to the ST support, I have received this project and soft to install in my PC. b...
Moved correct code doesn´t work
Posted on March 24, 2013 at 14:39Hello, I have really strange problem. 1) I have correct working code placed in main() function (for example for generating DC signal). It is working, but when I move this part of code into some function for example ...
j3lda by Associate II
  • 2078 Views
  • 5 replies
FreeRTOS Project Template for STM32L-Discovery BSP
Posted on March 25, 2013 at 20:29Hi, I would use the FreeRTOS on my STM32L-Discovery board with IAR EWARM. I am finding a Free Project Template that I can use to develop an example application. All demo Application inculded in the demo folder of the...
ibis model availability?
Posted on March 18, 2013 at 07:30Hello all,I am trying to import ibis model of STM32F4 series micro controller to eCAE simulation.I found ibis model for stm32f2 and 1 but not F4 series.Is there any ibis model for stm32f4 available for download or an...
kyuhyong by Associate
  • 1723 Views
  • 3 replies
Procedure for changing FLASH waitstates
Posted on March 25, 2013 at 10:46While playing with some benchmarking code on STM32F4, I came across an interesting phenomenon: I was changing the FLASH waitstate in the LATENCY field of FLASH_ACR register, and sometimes the subsequent code run at a...
Sending data from stm32f4 to pc
Posted on March 24, 2013 at 20:27hi,i am trying to send data from accelerometer to pc using virtual com port ,but when i open hyper terminal to check if data was sent i found out unsignificant symbols!!!this is the  systick handler wich is called wh...
karoui2 by Associate
  • 1322 Views
  • 1 replies
