STM32 MCUs Products
STM32F4 Power scale modes
Posted on September 13, 2013 at 10:40Hi Folks I been looking for information on the power scale modes of the STM32F4 and I've not been able to find any information on them - is there a good doc out there that explans them?? Thanks CS #pwr #stm32f...
bl by Associate II
  • 1898 Views
  • 3 replies
Help needed to layout stack and heap on a STM32 F0
Posted on September 13, 2013 at 11:39Hi, I'm doing my first project with the STM32F051x8. Yesterday may code was not running in cause of heap problems. I played around with the 'startup_stm32f0xx.s' file, set different sizes for Stack_Size, HeapSize...
matthias2 by Associate II
  • 1422 Views
Inpute Capture
Posted on September 12, 2013 at 08:54 Hi, I'm working with STM3220G board.I am interested to understand input capture and I'm buildinga small project to capture input of Key button, but it doesn't work. This is my code: #include ''...
mosine by Associate II
  • 1757 Views
  • 6 replies
BSDL files for STM32F4 Discovery board
Posted on September 12, 2013 at 16:24Hello,I'm looking for BSDL files for my STM32F4 Discovery board (STM32F407 VGT6).I did extensive search on your webpage, but I was not able to find it.Could you please provide the file to me?thanks! #stm32f4 #...
Problem with example USB code and RTC
Posted on August 07, 2013 at 20:47usb_bsp.c, V1.0.0, 19-September-2011 in USB_OTG_BSP_Init() makes this call:    RCC_APB1PeriphResetCmd(RCC_APB1Periph_PWR, ENABLE); That goofs up prior configuration I had done to the RTC. Is that a bug in the librar...
STM32L timebetween pulses
Posted on September 06, 2013 at 15:35 Hello,I'm trying to measure time between two pulses on a pin. Time between pulses is in 10 - 100 uS range so I can't use millis function. What I'm trying to do is use TIM2 CNT register. Since my APB2 clock is ru...
k_ by Associate II
  • 4632 Views
  • 10 replies
Configure channel3 Timer2
Posted on September 10, 2013 at 16:45 Hi, For the moment I am using the channel2 of the Timer 2 in capture mode. At each rising edge of the signal, the timer is captured and reseted; It works fine; My code is this following: G...
gfoujanet by Associate II
  • 1627 Views
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
