STM32 MCUs Products
SPI with mixed DMA / manual XFER and TXFIFO issue
Posted on February 15, 2015 at 21:59I am using SPI in slave mode with a mix of manual transmission/reception at the beginning of my message protocol (first 3 bytes manual), then DMA in the middle for the data transfer, then manual ACK/NAK byte respo...
gahelton1 by Associate III
  • 1738 Views
  • 4 replies
STM32F303 clock startup
Posted on March 06, 2015 at 15:15With a clock module connected to the OSCin (HSE) does the chip start up using that or does the internal osc start the MCU and a s/w setup change over to the external clock? Otherwise how does it know what frequency i...
gbigden by Associate III
  • 1920 Views
  • 9 replies
External memory newbie question
Posted on March 08, 2015 at 00:19Hi everyone, thanks for the time you�re taking for reading this.I�m trying to make a small board that�s capable of running linux for testing purposes. There are for sale some system on modules (SOM) that seem quite r...
leaf05 by Associate
  • 1247 Views
PWM Input capture doesnt work on Ch3&4 pair
Posted on June 24, 2013 at 09:16Hello I am using STM32F05XXX uc and PWM input capture example provided with the standard peripheral library for measuring frequencies of 2 different pulses.Since the example had support only for the input capture usi...
sajeed by Associate II
  • 3279 Views
  • 9 replies
Interfacing ARM and AD8403
Posted on February 20, 2015 at 12:15The original post was too long to process during our migration. Please click on the attachment to read the original post.
