STM32 MCUs Products
STM32 FMC Display
Posted on July 12, 2016 at 08:23Hi everyone, I have a display hooked up to an STM32F767 via the FMC and all is working properly.  When I try to use DMA2D the DMA2D will only transfer the first 64K of data.  There is no error generated, it appears to...
gvigelet by Associate II
  • 2006 Views
  • 3 replies
STM32L1 HSE/PLL failure
Posted on July 11, 2016 at 13:56Hi,2 questions about HSE/PLL :1. Supposing the HSE/PLL is running fine, is it possible that it suddenly stops running without any reason ?2. If yes, what happens about the SYSCLK ? Does it switch to HSI ?Thank you for...
Kuikui by Associate III
  • 2299 Views
  • 4 replies
Registers datasheet
Posted on July 12, 2016 at 17:42Hi, I am currently using the STM8L152C6 MCU but I can not find the datasheet about registers.I looked at all datasheets present on this http://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-...
thibaut by Associate
  • 1085 Views
STM32 Nucleo F411RE UART
Posted on July 11, 2016 at 15:50Hello, I am trying to modify the given code for STM32F411RE nucleo board. I want to modify the UARt code by including an interruop section.I have the following code:&sharpinclude ''mbed.h''//--------------------------...
ADC and DAC via DMA
Posted on July 12, 2016 at 14:33Hi,I need to know the exact sequence to be adopted (if any) in order to use the STM32F3xx HAL drivers to implement the ADC multimode conversion with transfer by DMA, using two separate DMA channels for master and slav...
flavio23 by Associate III
  • 834 Views
  • 0 replies
STM32F746 - Problems with FMC
Posted on April 16, 2016 at 11:10 Hi all, I'm trying to use a LCD via the FMC, but as yet i haven't been able to get any output from the FMC module at all. Using normal GPIO pin writes works just fine. Im using this test code to diagno...
mwp by Senior
  • 1202 Views
  • 3 replies
