STM32 MCUs Products
Resolved! HAL geniuses, how does this work?
Posted on June 16, 2017 at 23:56From the STM32F412G-DISCO demouint32_t HAL_GetTick(void){ return (DWT->CYCCNT / (HAL_RCC_GetHCLKFreq() / 1000)) ;}How exactly does this wrap properly within the 32-bit number space? Answer: IT DOESN'T
STM32CubeMX HCLK clock configuration 30MHz limit
Posted on May 23, 2017 at 10:55Hello,I am trying to reduce the HCLK frequency down to 8MHz or less on an STM32F405 MCU.Using STM32CubeMX, when I configure an HCLK clock lower than 30MHz with the clock configuration tool, the box with the HCLK freque...
Dulan D by Associate II
  • 3100 Views
  • 7 replies
STM32L476 on NUCLEO-L476RG Baudrate with CubeMX
Posted on June 29, 2017 at 16:01Configured USART1 of mcu to 500 kbit/sec using STM32CubeMX Version 4.21.0.Code created by Cube seems to be correct.Measurement shows that bitrate is 250 kbit ( a 10 bit character needs 40 µsec).See Attachements.USART...
JuM by Senior
  • 1130 Views
  • 1 replies
STM32F469I-DISCO - CubeMX project file for LCD
Posted on June 29, 2017 at 08:03Hi,I prepared several project files for a few DISCOVERY boards (I shared examples for STMF429, STM32F746, STM32F412, etc), but this time it seems to take more time than I expected. Maybe someone from you guys already ...
STM32F303 SPI bus
Posted on June 22, 2017 at 20:13Any reason not to drive 6 L6472 daisy chained devices directly from the STM32F303 SPI bus?  Running at ~1MHz.
D S by Associate
  • 871 Views
  • 1 replies
Arduino UNO with X-NUCLEO-IDB04A1
Posted on June 27, 2017 at 12:54I recently bought a X-NUCLEO-IDB04A1 and wanted to use it with Arduino. How do I go about it ? Please help me out.My aim is to collect the sensor data from http://www.st.com/en/ecosystems/x-nucleo-iks01a1.html and sen...
F767 ethernet errata and DBGMCU_CR
Posted on June 22, 2017 at 14:35Hello,the Ethernut (http://www.ethernut.de) STM32 Ethernet driver from svn head (/sourceforge.net/projects/ethernut/files/) works reliable for F107/F2/F4 and F74. However for F767 Revision A chip (no Rev Z chips avail...
Multibuffer communication for STM32L4 UART
Posted on June 29, 2017 at 06:35I am looking for a method to build uart rx/tx circular buffers for STM32L476 which communicate using DMA. In 40.5.2 of http://www.st.com/content/ccc/resource/technical/document/reference_manual/02/35/09/0c/4f/f7/40/03...
STM32F207 USB HPOST fail after reconnect
Posted on March 22, 2015 at 17:50I found the problem. When I quickly connecting/disconnecting USB device(LS HID mouse)  from STM32F207 USB host FS port the occurs another situation: USB constroller  stop generate host channel and/or port/disconnect ...
