STM32 MCUs Products
Using two 16bit bus SDRAM as 32bit
Posted on July 11, 2017 at 15:23Hello,I'm designing an application using STM32F469BIT6 and two AS4C4M16S 16bit bus SDRAM to be used as external program memory.My idea is to use 4 byte enable (NBL0~NBL3) sending the lower two (along data [0~15]) to o...
Resolved! STM32F411CC - (256kB) Flash Sectors
Posted on July 10, 2017 at 18:49Can anyone confirm what the Flash sector sizes are on this MCU version?All documentation lumps the F411xC with the F411xE even though the former has 256kB of flash, and the latter has 512kB. The stm32f4xx_hal_flash_ex...
USART2 does n't work on STM32F302
Posted on July 11, 2017 at 14:08Hello Everyone, I am trying to send  string on USART2 of STM32F302 but I am not succeed ,  my Code worked on USART1 and USART3. Does any one help me ?#ifdef __GNUC__   /* With GCC/RAISONANCE, small printf (option LD L...
Encoder mode and interrupt on every edge
Posted on July 10, 2017 at 15:58Hello,I have question about encoder mode. Can I use encoder mode for counting pulses and also generates interrupt on every counting pulse ? I need to set some variable on every encoder edge.RegardsRafal
STM32F3 read data from BME280
Posted on July 11, 2017 at 10:09Hi,I'm a newbie, I want to read data from BME280. But I really didn't how to read data with a STM32F3 discovery board.Please help me an example similar to BME280 or an anything similar#phuoc_nk
Field updating of STM32 with data in external qspi flash
Posted on July 05, 2017 at 02:51Hi All,We are using an STM32F7 processor.We have a typical application that will store LCD images and other asset type data in qspi flash. The QSPI flash will be memory mapped. We also have external memory mapped RAM....
imtiaz by Associate II
  • 7566 Views
  • 16 replies
configure nucleo-l496zg-p for smps
Posted on July 09, 2017 at 19:45Does anyone know how to configure the Nucleo-L496ZG-P for SMPS operation, specifically to run the supplied example PWR/PWR_RUN_SMPS/Src/main.c#smps #l496
Resolved! BSP library failed to link with HAL library
Posted on June 28, 2017 at 17:51I use BSP/STM32469l-Discovery (from STM32CubeMx) , and use STM32F4xx_HAL_Driver to do a small project like this video : https://www.youtube.com/watch?v=u_TVAudWabI  (I convert evaluation board from STM32F429-Disco to ...
Dai chou by Associate
  • 2818 Views
  • 4 replies
