STM32 MCUs Products
I want to get information for STM32H7 Series.
Posted on March 17, 2017 at 02:14Hello.I want to know more specification of STM32H7 series.But, Information was not in ST site.So I want to get datasheet and reference manual for STM32H7.If it is possible to share, could you open more information.I ...
STM32F107 Jump To System Memory - Bootloader
Posted on July 15, 2017 at 18:36I'm using the STM32107 and want to use application code to activate the STM32 bootloader in system memory. I've consulted the AN2606 Application Note where it states...'In addition to patterns described above, user ca...
Resolved! Why USB CDC + FreeRTOS code created by CubeMX does not work?
Posted on July 15, 2017 at 16:09Hello.I am using STM32F746BG. I use FreeRTOS and USB CDC class code.when I create an IAR Project using STM32CubeMX, USB com port correctly identify by windows but can not open.but if i change code like cod below, it w...
mn by Associate III
  • 2259 Views
  • 4 replies
STM32F411x I2C addressing: 0x78
Posted on July 15, 2017 at 11:06I am using the STM32F411 as an I2C master to control a DC_DC converter with PMBus support.This device is within a local system, and it allows all 128 addresses to be assigned with seven user-assignable address pins. S...
Luca R by Associate II
  • 2848 Views
  • 4 replies
Stm32CubeMX - STM32F7 Library Install Issue
Posted on November 20, 2016 at 18:08I get an error each time I attempt to install the library ''Firmware Package for Family STM32F7'' into STM32Cube MX.  This occurs after removing the original Zip files and uninstalling reinstalling STM32CubeMX. Th...
jdsotack by Associate II
  • 2089 Views
  • 3 replies
STM32L151 + TMP100 temp sensor ==> I2C always busy
Posted on July 15, 2017 at 13:09Hello everyone, I have looked up this issue but I am afraid I have been unable to find a solution. I have a TI http://www.ti.com/lit/ds/sbos231i/sbos231i.pdftemperature sensor connected to a stm32l151 MCU by way of I2...
Unable to correctly debug my board
Posted on July 14, 2017 at 21:55Hi,I've uploaded STM32CubeMX to 4.22.0 version and the firmware for F1 family to 1.6.0 version. I used Cube software to update the HAL libraries in my project and since then I'm unable to correctly debug my board.The ...
STM32F469I vs STM32469I (What is the difference?)
Posted on July 14, 2017 at 05:17I have recently got a STM32F469I-DISCOVERY board to start embedded development on STM32 family. I downloaded the Firmware package for F4 devices from http://www.st.com/en/evaluation-tools/32f469idiscovery.htmlThis is ...
