STM32 MCUs Products
It's possible to upload a file to STM32F446RE?
Posted on July 23, 2017 at 17:10Greetings,I'm developing a system to test ECG equipment using the STM32F446RE board and I need to upload a file to the flash containing samples of a ECG signal, I'm currently using mbed to test the ADCs and DACs, but ...
Composite USB example (2xCDC) for STM32F7
Posted on October 27, 2016 at 11:08Hi. Based on chinzei.tsuneo's code in [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Multiple%20USB%20CDC%20%28USB%20IAD%29.%20...
jmasriera by Associate II
  • 2405 Views
  • 4 replies
STM32F407VG design files
Posted on July 25, 2017 at 15:25Hi,Can some one help to find the design files of STM32F407VG discovery kit. I see pdf document in the website. I need the design files.ThanksSuresh
Resolved! STPM33 RMS calculation
Posted on January 24, 2017 at 13:54Hello,I'm working on an energy meter system using STPM33. I designed and assembled PCB. For testing I wanted to use STPM3x Evaluation Software. I can communicate with STPM, I can read and write registers. To see if...
Resolved! Independent Dead-time for Advanced Timer
Posted on July 21, 2017 at 01:50Hi All,I'm using the advanced timer TIM1 on STM32303VC to drive a 2 phase shifted full bridges separated by a transformer (Dual Active Bridge topology). This required use of 4 PWMs. CH1 and CH1N drive the primary brid...
WKUP pin with internal Pull-Up
Posted on July 19, 2017 at 12:42I'm working with the STM32F769, and I want to configure the pin PA0 to wake up the MCU from Standby. The problem is that the board needs a Pull-Up in the pin to be able to detect the pulsation.The sequence that I foll...
STM32l053R8 standby mode with RTC wake up
Posted on July 25, 2017 at 09:43Hi,           I'm trying to configure the wake-up time period for the stm32l053 discovery board in standby mode . From my understanding of the datasheet provided, Internal RTC works with LSI (38 KHz) & It cannot be va...
LRPS_92 by Associate II
  • 972 Views
  • 0 replies
Resolved! Why does Nucleo's PA 3 terminal show 3.3 V with ADC
Posted on July 25, 2017 at 01:56Thank you for your patronage. I'm Japanese student. Sorry for my poor English.I'm using STM32F334Nucleo.Nucleo's PA 3 terminal indicates about 3.3 V in ADC in a situation where nothing is connected.On the other hand, ...
0690X00000607feQAA.png 0690X00000607g0QAA.png 0690X00000607fZQAQ.png 0690X00000607fjQAA.png
Ken Inoue by Associate III
  • 1706 Views
  • 5 replies
