STM32 MCUs Products
Blue Pill external interruption
Posted on August 26, 2017 at 02:37Hi,recently I started my adventure with STM32F103C8T6. I had some experience with programming on other boards e.g STM32F3 Discovery but I came accross a problem with external interruptions. I am using EclipseStm as ...
wojtek s by Associate
  • 1027 Views
  • 0 replies
[OTG + documentation + Cube] OTG_FS interrupts in 'L4
Posted on August 25, 2017 at 21:20More.RM0351 rev.5 says thatThere's no other OTG_FS interrupt mentioned in that interrupts table. Does that mean that EXTI line 17 should be enabled to be able to receive the OTG_FS interrupts?Turning to the EXTI cha...
STM32_cube_LORA
Posted on August 25, 2017 at 15:17Hello , i'm using developpement kit ( B-L072Z_LRWAN ) , with the provided cube code ( End node), when downloading it, i'm expecting receiving at gateway null values for all sensors returns because there is no shield...
Kim ElQ by Associate II
  • 706 Views
  • 0 replies
External FLASH for F765 with the FMC
Posted on August 25, 2017 at 15:09Greetings All!In the past, we have used the F4 series (F427) with the FMC memory controller, to interface with 2GB of external NANDFLASH memory.  This worked with no problems.NOW, we have the same setup (same wiring...
