STM32 MCUs Products
Resolved! i am working on stm32f030c6t6 microcontroller.
Posted on April 23, 2018 at 10:35Hi all,I am working on stm32f030c6t6 microcontroller. I want to use tim3_ch1 as pwm output. datasheet says that tim3_ch1 alternate function is available at two pins PA6 and PB4.I am not able to find that which pin de...
sanju by Senior
  • 2735 Views
  • 6 replies
How to repair broken line
Posted on April 24, 2018 at 03:40Hi,I have a STM32 F746ZG.I have to patch the NUCLEO board on the back side:remove SB121andclose SB122solder bridges.I do it. But I made broken line.How to repair broken line?*I want to close SB122 soder bridge for us...
Writing my own Bootloader
Posted on April 23, 2018 at 17:38Hi  I have looked on the forum, and see there is a lot of info regarding this topic. I am coming from a 68S09 processor where I designed my own bootloader that done the following: 1. User first downloaded new firmwar...
Move data into GPIOx_BSRR by DMA?
Posted on April 23, 2018 at 20:33I'm using SMT32F429.I want to move 32 bit data from memory into GPIOx_BSRR by DMA and use a timer as trigger.I tried to setup DMA1 Stream 4 channel 1 (TIM7_UP). And I setup Timer7. But I end upp getting Stream 4 tran...
sima2 by Associate III
  • 1209 Views
  • 1 replies
UART Driver for STM32F413H
Posted on April 23, 2018 at 10:07Hi All,I am working with STM32F413H disco kit. Configured UART2 driver with 4 wires(Tx,Rx,CTS,RTS).I am using UART in interrupt mode. Trying to send and receive some data with loopback test.But when UART_Recv_IT is g...
STM32Cube_FW_H7_V1.2.0 Bugs - NUCLEO HSE_VALUE
Posted on February 15, 2018 at 18:29STM32Cube_FW_H7_V1.2.0\Projects\STM32H743ZI-Nucleo\Applications\FatFS\FatFS_uSD_Standalone\Inc\stm32h7xx_hal_conf.h\STM32Cube_FW_H7_V1.2.0\Projects\STM32H743ZI-Nucleo\Applications\LwIP\LwIP_HTTP_Server_Netconn_RTO...
Evaluation board for STM32L486
Posted on April 23, 2018 at 05:48Hi ST fellows,I want to use http://www.st.com/en/microcontrollers/stm32l486rg.html&sharpsw-tools-scroll  I do not see any development board for this MCU.  Can you please suggest some eval. board or discovery kit to t...
