STM32 MCUs Products
STM Cube MX BluNRG MS Bug
Posted on June 09, 2018 at 00:54Hello,when I try to open the example with cube to generate code this message appearBut download doesn't work because the current version 12 is not RC1.regards
0x90 by Associate II
  • 2358 Views
  • 7 replies
Resolved! output compare channel problems
Posted on January 26, 2017 at 10:35Hello everyone, I want to use timer output compare channels as internal timebase (no output pins used). I did generate the following code by CubeMx/* TIM3 init function */static void MX_TIM3_Init(void){TIM_ClockCo...
Websocket Server support for SPWF04Sx
Posted on June 25, 2018 at 15:49Are your WLAN Modules (SPWF04Sx + SPWF01Sx) supporting WebSocket-Servers or are only clients supported?In your document UM2114 you describe AT-Commands for TCP Socket Server and Clients, but for Websockets I found onl...
CubeF0 1.9.0 ceases Atollic support. Why?
Posted on September 27, 2017 at 09:54Hi !Does anybody know the reason for:Projects:Remove support of Atollic TrueSTUDIO STM32 (TrueSTUDIO) toolchain.Are all Cube versions affected?Best regards,HaJo
hjs by Associate II
  • 2830 Views
  • 7 replies
Resolved! USB device mode, low speed
Posted on June 24, 2018 at 14:07Can the USB controller of STM32F072 work in LOW speed mode?A. Is it possible to enforce low speed mode against a host capable of FS and HS?B. If a host is low speed only, will the USB controller work with it? I've tri...
Pavel A. by Super User
  • 3231 Views
  • 1 kudos
Resolved! STM32L4 LSI and power-down sequance
Posted on January 14, 2018 at 09:25Hello,In our Evaluation board of the STM32L486QG we encounter in strange behavior of the MCU.When the power supply turned off and on quickly we saw that sometimes the MCU start to getting in to loops of IWDG.We are...
shachar y by Associate II
  • 2205 Views
  • 7 replies
