STM32 MCUs Products
STM32F072 LSI Calibration
Hello, I recently started with embedded programming and currently I'm tasked with LSI Calibration based on LSE clock, this would be useful when the device enters low power mode. Based on this reference manual:https://www.st.com/content/ccc/resource/t...
Ismet by Associate
  • 1675 Views
Deadtime about PWM
i config TIM with PWM , and insert deadtime , i found the first deadtime is longer than later , this why behave so ?​
STM32L05 + SPI not work after stop mode
Hi,I am trying to use an e-paper and a STM32L053C8 microcontroller.When i use the display in the first cicle, all works fine, but after wake up from stop mode, the display not works. Maybe the SPI interface not start well or i am doing somthing wrong...
SMila by Associate
  • 746 Views
  • 0 replies
OCTOSPI with dma used for external DAC
Hallo.I want to use OSPI to feed an external DAC with data.Data shall be transfered through DMA from memory to OSPI. Eight bits and OSPI-CLK shall be used.In the first place I set up OSP in octo mode, disabled all IRQ etc. and tried to write one byte...
edemier9 by Associate II
  • 804 Views
  • 0 replies
