initialise structure array ??
hello
I have a structure array
typedef struct
uint8_t Line_Add[lcd_lines];
char Line_Data [banks] [lcd_lines] [40];
uint8_t Data_Pos [lcd_lines];
uint8_t Start_Pos [lcd_lines];
uint32_t Flash_Bit [lcd_lines];
uint8_t Alt_Flash_CharPos[lcd_lines];
} lcd_module;is there anyway I can set some default values to
uint8_t Line_Add[lcd_lines]; i.e ={1,2,3,4}
I don't know how to set some initial value to member array in a structure
any help as always much appreciated
regards
