STM32 MCUs Products
HAL_SPI master OVR error
Hi everyone,I'm using the STM HAL for my SPIcommunication in master mode. Toreadout my ADC, I implemented a state machine, which startsthe ADC conversion and then once a data ready signal is received, the data isclock out in SPI full duplex mode. Onc...
DZimm.9 by Associate III
  • 1110 Views
  • 0 replies
Executable format for flashing under Linux
Hi,I use Linux as a development environment for STM32F429. I've created several Makefile files for my project and I'm able to compile it. Now I'd like to flash project's output binary file to STM32F429. I know that it is possible to mount STM32F429 ...
WKowo by Associate II
  • 2485 Views
  • 3 replies
I2C Reception Issue with DMA in HAL Library
HelloI am implementing I2C transfer with DMA in stm32.Processor: stm32l152rdt6DMA Configuration:I would like to continuously receive 3 bytes from master, so I use circular mode.NVIC Configuration:I2C Initialization Code: hi2c1.Instance = I2C1; hi2...
MHuan.18 by Associate
  • 849 Views
  • 0 replies
  • 1 kudos
What is the impact of overlapping ADC conversion on STM32H743?
In the STM32H743 errata sheet (ES0392 revision 4), section 2.3.1 “Conversion overlap may impact the ADC accuracy�? leaves me with three questions:If I am reading correctly, this means that running conversions on two different ADCs, from two different...
CHead by Associate III
  • 2222 Views
  • 4 replies
More documentation about VOSRDY
Hello,STM32F4 and F7 have a VOSRDY bit in PWR->CSR. Documentation about the bit is nearly not existant. On a F4, while still running on HSI, I changed the VOS setting. Waiting for VOSRDY in that state never succeeded. Looking for that bit just before...
