STM32 MCUs Products
How to disable UART temporarily?
Hi,i send data to STM32F4 from STM32F0. then i send these values to thingspeak using ESP8266. but it works onle once. after i send values to thingspeak using ESP8266 it returns endless trash values via UART2. and i can send data from F0 to F4. so i h...
STM32 ADC problem
I am using STM32F030F4P6 when I call this Function my ADC starts successfully and I can read ADC value in ADC callback but my MCU hangs at this function line what is the problem? My code is generated by st32mcubemx and my IDE is IAR. I have a problem...
AAg.14 by Associate
  • 2340 Views
Resolved! RN4020 Uart Communication with Stm32L100 Discovery Board
Hi,I am trying to communicate RN4020 with my STM32L100 disco board however I could not manage to do it. I can send commands and get AOK and Reboot responses when I try it with an Arduino. I did monitor that Disco can communicate correctly with Arduin...
herca.1 by Associate II
  • 1687 Views
Oryginal H750
Hi! I want to buy ~cheap​ but oryginal STM32H750.Are there fakes and how to spot them? What is target ID of *vbt6 chip?​On china market this chips costs 1/2-1/3 the price than in quite reliable seller in my country.​Im hobbyst so I first consider rel...
oeliks by Senior
  • 884 Views
  • 1 replies
Is it possible to obtain 32 channels (single ended) of 16 bit AtoD conversion (15KSmps per channel), and set individual per-channel gain with onboard OPAMP in PGA mode?
The idea is to change PGA gain before every conversion, but I can't find any info about the time that PGA needs to change the gain.Manual states that it is possible to have up to 36 16bit channels of ADC. Manual states that PGA could be attached to A...
SD.11 by Associate
  • 649 Views
  • 0 replies
We can add DMA interrupt for the stm32f042x6 ?
We have 3 DMA interrupts  DMA1_Channel1_IRQHandler, DMA1_Channel2_3_IRQHandler, DMA1_Channel4_5_6_7_IRQHandler, i need use 3 interrupts beer 2 channels because i use 3 usart with DMA (3 x channels for TX and channels for RX). 1- i can split the chan...
