STM32 MCUs Products
How Indication works
Issue: How to send indicationhow can get confirmationHow to disable indication from server to clientHow to know client all data received from serverMy Code is:       bool isIndicationEnable;       if (attribute_modified->Attr_Data[0] & COMSVC_Indicat...
Debug
Hello STM community, I'm using a STM32 L476RGB NUCLEO with a XNucleo 53l0a1 I want to make the process of calibration but I have a problem when I compile my main program i get this error showing anyone know what i should do? you can see the screenTha...
MSAMB.1 by Associate III
  • 1381 Views
  • 1 replies
Resolved! Probleme on getting clock signal on SPI slave device,
Hi ,i have a problem with SPI slave device, it doesn't receive the clock signal from stm32f103 (Master), i have configured the baud rate correctly : 72Mhz/32 (SPI1), which is inside the range clock freq of slave device, CS pin is active low so when i...
SIDRI.1 by Associate III
  • 1029 Views
  • 1 replies
Communication with interrupt between 2 cores
Hello,I am trying to communicate with interrupt between the Cortex M4 and M7. I tested the HSEM but, maybe I'm wrong, the semaphore locks a process when it waits for it.Thanks for you help
OADDI.1 by Associate II
  • 1936 Views
  • 3 replies
