STM32 MCUs Products
I want to generate 4 phase pwm for interleaved buck converter with independently controllable duty on each channel. I am using stm32f103 series mcu. I want to know if its possible with this micro controller .
I am told by that configuring a timer as master and others as slaves can generate multiphase pwm . but I cant figure out how exactly to set the configuration. I am aware its possible in few of the advanced MCU with HRTIM. But I want to use stm32f103 ...
Arg.1 by Associate II
  • 3912 Views
  • 5 replies
  • 2 kudos
When will I get more info about this STM32U5 chip?
I've just noticed this upcoming STM32U5 - it looks amazing - and in LQFP48 package too!. FMAC, DC-offset filter for PDM microphones, inbuilt SMPS regulator. When can I see a Data sheet and reference manual? Mainly interested in seeing more info abou...
gregstm by Senior III
  • 1488 Views
  • 3 replies
STM32 CAN Bus not sending the messages
Dear sirs,I am trying to communicate through CANBUS an F407 and an H757 with external MCP transceivers.The problems I have are:-For the F407, If I set the mode to Loopback, I see with my external logic analyzer that it sends the message in the CAN1_T...
VCasa.3 by Associate II
  • 6597 Views
  • 5 replies
Stop mode and peripheral clocks
 Hi. I'm looking for guidance on entering and exiting Stop mode. L4, but probably applies more broadly. The RMs explain how to enter it, but I'm unclear on RCC effects.PLL oscillators other than HSI or MSI (depending on family) are disabled and desel...
DOCon.1 by Senior
  • 2508 Views
What kind of wire could I use to power my STM32F769I-DISCO?
Hello! I've bought that kit and I would like to know where I can find the kind of wire which could enable me to power it without using either USB ports or Ethernet one.Below a picture which shows you this input with the mention "5 V power supply inpu...
LleytoN by Associate II
  • 1309 Views
