STM32 MCUs Products
Custom board using STM32L053C8T6
Hi All I am trying to build a custom board (for the first time :)) using an STM32L053C8T6. The board will power an LED and do short burst measurements of its reflection off a strip (< 1s). I am trying to power up the board using a photovoltaic cell a...
NSoin.1 by Associate II
  • 2232 Views
  • 6 replies
STM32F746 FMC configuration
Using STM32F746, I want to access Intel's 10AX032H2F35I2SG FPGA.During FMC Configuration, I do not know how to calculate and write the following parameters.I've seen the RM0385 documentation, but I don't know how to calculate it.I have to do it by to...
Psang.1 by Associate
  • 1015 Views
  • 1 replies
STM32L4R5 || Flash internal read/erase
Hello everyone,Dev Board based on STM32L4R5I am just trying to erase and then write something on the internal FLASH.I am trying to follow the example: https://github.com/STMicroelectronics/STM32CubeL4/blob/master/Projects/NUCLEO-L4R5ZI/Examples/FLASH...
POval.1 by Associate II
  • 3023 Views
  • 5 replies
How to send data via CANFD from stm32H753AI to PC?
Hello,i am pretty new to this topic. I want to send simple data via CANFD from the stm32H/53AI to a PC. For that i have the CANFD-USB adapter from PEAK and to display the data i am using PCAN-View. I discovered the function and i put in the addresses...
PHumm.1 by Associate
  • 1820 Views
STM32L496 - SD Card SDIO write speeds (FreeRTOS, FATFS and USB), how to get "fast" (> 100kbytes/sec) throughput?
Hi all,I need to stream data into an SD card, at about 25KBytes/sec max. Currently I'm stuck at 11kBytes/sec, but the SDIO data transfer works, kind of. I'm using an STM32L496 board, FATFS and FreeRTOS, as well as USB.The USB part works actually real...
AFahr.1 by Associate III
  • 12113 Views
  • 28 replies
  • 4 kudos
