STM32 MCUs Products
Cannot read low current consumption on STOP2 mode with my STM32L412 board (~300uA+-), but using the same code and compatible with my STM32L476, i succeed (~3uA). ill be happy to work with low consumption with the STM32L412, can any one help me with that?
Hello guys, first, i would like to thank you about this forum i used a lot and got good suggestions and i learn a lot from you.About my problem:I checked a lot in the internet and see others that had the same problem like mine, but didnt find any wit...
Ypinh.1 by Associate III
  • 1410 Views
  • 3 replies
Frame synchronization randomly swapping.
I have a STM32L433 driving a FDA802 using SAI in I2S standard mode, and it randomly swaps the left and right channels. I have compiled with a small table of interleaved data (two sine waves of different amplitudes) to try an fault find. the code I am...
KJans.1 by Associate II
  • 1649 Views
Resolved! STM32G0 TIM2 with DMA Burst Transfer (not working)
I have a STM32G071 nucleo and want to generate an arbitrary waveform on PA0 via TIM2-CH1.I am using the HAL_TIM_DMABurst_MultiWriteStart API: it should do bursts of 3 writes to multiple registers (ARR and CCR1).Problem is, the DMA only updates the AR...
a34fheuak by Associate II
  • 18309 Views
  • 3 replies
  • 1 kudos
stop working when I unplug the JTAG port
HiI created my own board with a STM32F411RE microcontroller. I can program it normally with a ST-Link v2 probe, the program works correctly.But from time to time when I disconnect this probe the board stops working. Can someone explain me why?On my c...
bvale.2 by Associate II
  • 2564 Views
  • 5 replies
