Vikas1
Visitor II
August 13, 2021
I would to generate option byte file in hex format
  • August 13, 2021
  • 3 replies
  • 1121 views
@Exmple:
:020000041FFFDC
:01F800000007
:020000041FFFDC
:01F80200FF06
:020000041FFFDC
:01F80400FF04
:020000041FFFDC
:01F80600FF02
:020000041FFFDC
:01F80800FF00
:020000041FFFDC
:01F80A00FFFE
:020000041FFFDC
:01F80C00FFFC
:020000041FFFDC
:01F80E00FFFA
:00000001FF
I was able to do the same in F series with the help of STVP tool, but in G0 series it is not possible.
Tesla DeLorean
Guru
August 13, 2021
Which STM32G0xx part specifically
I think the G0 have the Option Bytes at 0x1FFF7800 rather than the 0x1FFFF800 range this HEX data shows for the F0 series, total 16-bytes
It might be possible to array similar records for the G0 series.
Typically an erase, and rewrite all type operation, right?
waclawek.jan
Cubeprogrammer supports this?
Tesla DeLorean
Guru
August 13, 2021
Not sure, not using G0 here, but Keil typically has a "Flash Algorithm" for the option byte memory when programming the devices.
