STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1570 Views
  • 0 replies
  • 2 kudos
Resolved! CubeMX not generating PLL2 code for USB
Hi,I am using STM32F105RC. CubeMX does not seem to configure PLL2 at all in SystemClock_Config(). Below in the clock configurator it is clear that I have enabled PLL2 to be used for PLLCLK and USB clock.Seems like a CubeMX bug. Or if someone can poin...
Toolchain/IDE should not be a single choice menu
I come from the world of web development, where we are spoiled by probably the best DX experience in the world in many cases, if using modern toolchains. Unfortunately C/C++ and embedded development lags far behind.STM32CubeMX can improve this situat...
thernstig by Associate II
  • 1417 Views
  • 2 kudos
Resolved! L4 TSC CubeMX Bug??
Hi, when I generate code for the SMT32L412RBTxP using TSC with CubeMX  I get duplicated entries in tsl_user.h.One channel does not work. So I edit Channel 2 to use the missing group and IO:It now works, but when code is regenerated with CubeMX it ove...
Lanceh by Associate III
  • 1722 Views
  • 3 replies
Resolved! STM32H745 FDCAN Clock Frequency
Greetings, I've been using FDCAN on STM32G0B boards at 64Mhz. I'm trying to configure an STM32H745 and it seems that the maximum clock frequency for FDCAN is 50MHz? 50Mhz itself is a very strange frequency and bitrates cannot be solved well using t...
Resolved! User Labels ... sticky/pinable/lockable?
When I change a pin configuration, the user-label I'd previously given the pin is removed and it reverts to the default.That seems to me to be a wrong behaviour ... I think it should stick be default, or should have an option to lock it.This was rais...
Issue with Linker Script in STM32CubeMX 6.12.1
Important Notice for STM32CubeMX Users Current Release: STM32CubeMX 6.12.1 Purpose: This release primarily addresses issues related to STM32MPUs. Problem: Issues introduced with the generated code for Makefile and CMake projects. Recommendation: For ...
SemerCHERNI_15-1729258098740.png SemerCHERNI_16-1729258098742.png SemerCHERNI_17-1729258098750.png SemerCHERNI_18-1729258098751.png
