STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1624 Views
  • 0 replies
  • 2 kudos
How to set up a STM32 touch sense project with CubeMX
Posted on January 30, 2017 at 12:21HiI am trying to setup a new touch sense project and have  question:I configured certain pins as TSC, how do I add the the middleware TSC LIb in CubeMx now? For my Nucleoboard L053R8 CubeMX under middlewares doesnt...
How to setup & use touch sensing with CubeMx
Posted on March 04, 2017 at 03:36hello. I am  luis.Recently I use stm32f051x touch sensing feature that setup touch sensing with CubeMx(the latest ver.).but after test touch sensing, I get touch sensing value only '1'.Searching St community, i have ...
luisfynn by Associate
  • 3433 Views
  • 4 replies
Resolved! CubeMX USB CDC VCP - Transmission problem
Posted on December 13, 2017 at 11:43hello,i am trying to send data to pc over the otg used as a virtual com port. The data is received with a terminal program (HTerm). In order to send data i am using the function CDC_Transmit_FS. For a basic test t...
Resolved! CubeMX - failure to install en.stm32cubel4.zip
Posted on December 08, 2017 at 21:56After CubeMX griped that my software was too old, I tried to upgrade from the New Libraries Manager, but there was an error downloading the file. I fetched the file manually, then tried installing using the New Li...
CubeMX -Uart interrupt work one time
Posted on December 10, 2017 at 11:16Hii'm config evboar  nucleo with CubeMX  the send  data work fine but  recive data with HAL_UART_RxCpltCallbacki's work one time and second time is stuck in  loop anddon't reach to HAL_UART_IRQHandler(&huart1) aga...
cubeMX Pin user label problem
Posted on November 10, 2016 at 16:01Pin user label disappears when I change the pin function in the cubeMX GUI. This is not an expected behavior, since the already given name of the pin has not changed. #cubemx
Bug report: STM32CubeMX 4.23 SD_initialize
Posted on October 26, 2017 at 13:12As I explaned inhttps://community.st.com/0D50X00009XkXviSAF, I have found another big error in the code generation of STM32CubeMX 4.23.In this case, the bug is related to FATFS + SDMMC. In my case, I am working wit...
