STM32 MCUs Products
Resolved! Error: Interlacing the process
I am using STM32H7 and using the M4 core to output GPIO to control peripherals.I share data between the two cores using the share memory protocol.On the M4 core, I have turned off all interrupts and only control GPIO, but when measured, there is stil...
H723 Cubemax:SPI cannot recieve data
  I has been devloping an ECG program with ADS1292R and STM32H723VGT6.I has been struggling with a problem. The ADS1292R uses SPI and it's register can be read if I use STM32C8T6 which configuerd by libray finction.But when I configuer program with H...
begall by Associate II
  • 3812 Views
  • 7 replies
  • 2 kudos
Resolved! STM32F103C8T6 does not seem to have RTC wakeup feature?
Hi, I am trying to use STM32F103C8T6 standby mode and wake it up with wake up feature of RTC, but in CubeMX I don't see that this MCU would have wake up feature under RTC settings. How do I wake up this MCU from standby with RTC and wake up pin?
JBond.1 by Senior II
  • 1552 Views
  • 1 replies
Keeping data on multiple STM32s in Sync
Hello,I need guidance on how to best implement a packet protocol to keep the data on multiple STM32F373 in sync with each other.  If possible, I would like to reach a 'refresh rate' of 30ms.  Packet payloads for data refreshed could be up to 50 bytes...
LMorr.3 by Senior II
  • 3537 Views
  • 6 replies
  • 1 kudos
STM32F411RE PC13 user button mode is only pull-up?
Hello ST community,I can't find on the st.com website the documentation showing the electronic circuit of the STM32F411RE, especially for the user button. In which document can I find it?On the web it seems that schematics from google image show that...
stm32f1 DMA to PWM first bit issue
Hi,Im new to stm forums so sorry if i make any mistakes.Im using a stm32f103RET6 since i am familiar with f103 and i need usb/other peripherals. Thus far everything works great. However...Im trying to offload some work from cpu to DMA by sending a pr...
Levi--G by Associate II
  • 7560 Views
  • 6 replies
How to read data from a sensor
So, I'm trying to read data from a dht11 sensor. In the datasheet says that you have to send high signal, wait 80ms, then low signal, and dht11 will start sending data.My problem is, I don't know how to debug this. I don't know how to see if I my sen...
pablo1409 by Associate II
  • 6699 Views
  • 6 replies
  • 1 kudos
Resolved! STM32F303 PWM generation TIM1_CH3
Hi,I'm having trouble getting PWM output on my STM32F303. I'm using CubeMX for pin config, then generating for Make for use with VSCode on Ubuntu. TIM1_CH3 has been configured for PWM output on PC2, and TIM1_CH2 on PC1. CH2 works as expected, while C...
kristblo by Associate II
  • 1789 Views
  • 1 replies
